Where should my gains be set?
there is no magic setting. you need to set the gains according to what you have. unplug the rca's to the amp. turn up the head unit about 2/3 to 3/4. make sure the gain is all the way down. plug back in the rca's and slowly turn the gain up until you hear distortion or bottoming out. turn down just a little. that is the ghetto way. it works though.
set it all the way if it wasnt supposed to be set all the way it wouldnt give u that much power
the amp does its power with gain and boost up all the way so just put both up at least 3/4 and u will be happy
this is an example of the wrong way to set gains.
I guess you don't run a Pioneer hu like me.
I have not got he subs yet. I was just wondering if any one had a similiar setup and how high did they set it? I want it to be as loud and hit as hard as possible, without distortion. The amp says 1600 and the subs are 1000, i was asking if it is possible to have the gain all the way up @1ohm(for maximum power) and still sound clean. Should i get a less powerful amp?
ENDOFDAYS said he had a similiar setup, maybe he can offer some advice?
doesn't matter if someone had the same setup. your gains will be set differently.
YOU'RE DOING IT WRONG
Sorry, kcdc, I had to. This is just asking for trouble, especially if you have a Pioneer HU.
Just turn your car off, set the gains to the lowest possible, and turn the HU up to about 3/4, and if you don't have a DMM (Digital Multi-Meter) the best you can do is just listen to it, and wait 'till it sounds like your woofer's dying. Then turn it down a bit.
And turn off any bass boost.
EDIT:: And Type ARRGHHHS can take a lot, but it all depends on what box they're in.
css3
css3
memphis, tn
skateboardkid
