2 ohm vs 4 ohm
4 ohms will be a final load of 2 or 8 ohms
2 ohms will be a final load of 1 or 4 ohms
if you get a 4 ohm speaker, look up amp specs of 2 ohm ratings
if you get a 2 ohm speaker, look up amp specs of 1 ohm ratings
omfg..//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Are you unaware that not all speakers have dual voice coils? Or are you just trying to confuse the fvck out of him?
incorrect
a dual 4 ohm subs final impedance is 2 or 8 ohms
a dual 2 ohm subs final impedance is 1 or 4 ohms
more info... http://mobile.jlaudio.com/support_pages.php?page_id=145
to the OG post, most amps put out more power the lower the impedance so you might get more wattage for your buck if you get a dual 2 ohm sub vs a dual 4 ohm sub, or if you get a 2 ohm sub vs a 4 ohm sub etc etc
Will two subs with dual 2 ohm coils enable you a final of 2 ohms?
If you are trying to get the most out of your amp and it is one ohm stable, get two 4 ohm subs and wire them parallel. Then your amp will run at one ohm and push max power. (And get hot)
i dont think i have ever seen you give correct information in a post, keep trying one day it will happen by accident
Actually, I aim to run what ever I get at 2 ohms, I know you can run a DVC 4 ohm at 2 ohm when parallel wired, but a few of the subs I find interesting is only 2+2, and I haven't figured out yet how to get these to work with an amp at 2 ohm.
It seems to be easy to run 1 ohm or ohm but getting the correct ohms wired either in parallel or series to achieve 2 ohms is not so easy! Thats why I went my route. Just get an amp that is 1 ohm stable...piece of cake!
This is the sub amo I use and I have had it for 9 months without any problems. Its a great price at $179!
http://cgi.ebay.com/ebaymotors/DIRECTED-D2400-2400-WATT-MONO-CAR-AUDIO-AMP-AMPLIFIER_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1416Q7c39Q3a1Q7c66Q3a2Q7c65Q3a12Q7c240Q3a1318QQ_trksidZp3286Q2ec0Q2em14QQhashZitem220292820094QQitemZ220292820094
mattcl321
mattcl321
Vancouver, BC
mannyahles
