where should i point my subs
this is my first build so im being quite adventurous just building it myself so im gonna keep it simple and just go sealed for this first one. so i take it that i should face them back and then maybe i can just play with it to see what i like the sound of better?
my first sealed setup was noticeably louder facing back, but others may have different experiences... i've never had a mustang either, just play with it, you'll know when it sounds right and loudest to you, but generally in my experience subs back has been the way to go...
ok well i think im gonna build the box so that i can turn it around as i want and leave enough wire so that i can do that.
anything that i should be aware of for my first build that may not be very straight forward?
if you encounter troubles, you can always come here and use the search button to find what you need... if there has been a problem in car audio install anywhere, they've talked about, or flamed on someone for not using the search button here...
mooseman16
mooseman16
Houston, Tx
PuffDaddy_d
