Where do you buy a subsonic filter?
dan5505
Im planning to port a sub to ~32 Hz. My amp's built in subsonic (infrasonic?) filter only has 2 choices, 15 and 35 Hz. I cant seem to find a filter for sale anywhere on the net. Does anyone have any recommendations?
ohh ok. From what ive been reading, i was under the impression that the driver could be damaged below the port frequency. Im planning on porting a 15" Fi Q and running it on a Kenwood KAC X812D. So how do you know if you need the filter? Try it out and see how it performs?
Ok, i plan to tune somewhere between 30 and 33 hz, mainly because Fi recomends between 28 and 33. I mostly listen to rock so i was thinking around 32 would be good. So if i set the amp at the 15 Hz setting, its no going to start to roll off till 15. Technically, i could damage the sub between 32 and 15 Hz if i port to 32 Hz correct?
dan5505
dan5505
Montana
dan5505
michigan born
    May 14, 2026
michigan born
    May 14, 2026
