where do i put the voltage meter at?
should i connect it straight to the battery or closer to the amp?
its just a stinger digital display
what voltage do you want to read? I do mine directly off the power and ground of the amp, with the REM going through a toggle switch from the 12v REM relay.
Don't you do the+ to the + on amp
- to the - on amp
and the meter has a 3rd wire for the remote wire. To tell it to turn on when the amps on
thank youuu thats what i thought just wanted to be sure
if the VM can handle the amperage I would put it on the power wire close to the amp and mount it to the box. It should tell you the rating somewhere.
- to the - on amp
^^^ x2 thats how i have mine, don't forget to calibrate the voltage meter using a dmm or something as reference after you have it hooked up.
lol, handle amperage, it isnt a fuse, because the wire goes to the amp doesnt mean the electrical system will FORCE amperage into it. I would put it on your amps wires since really, that is what you need to be concerned about.
deLeo
deLeo
FL
jdawg
michigan born
    May 14, 2026
michigan born
    May 14, 2026
