When speakers blow
Thanks, but that would also limit the power to the subs as well right? I was hoping I wouldnt have to do that because there wont be much power going to them
Its a 4 channel, rated at 125 rms per channel at 2 ohms, and 80 per channel at 4 ohms. There are the 2 subs and four speakers, I was thinking of running the rear speakers from the HU, and the fronts and the subs from the amp. If I wired the four front speakers into two channels at 8 ohms, I dont think it would really supply enough power to them.
Definitely not. If you must have rear-fill, definitely run it off your HU. I've read that giving them the equivalent power to your fronts is part of what screws your sound-stage up. I purchased a 4-ch but I'll probably end up powering some mid-bass off my HU. Gimme some specific part names. What impedance load are you attempting to power the subs at, exactly? You either need to go 4 or 1; I don't know what your amp does bridged or if it's 1 ohm stable..
I don't think you should do it...even with the gains all the way down...thats like a 40 watt difference. I would just recomend buying a amp just for the subs and then for all four speakers.
I dont have the amp yet, but I was going to buy a profile ap1040, becuase this is a budget project for someone else, and ive heard profiles are reliable amps, and good for the money. Anyone know of an amp that is 1 ohm capable that would fit this situation? That way I could run the fronts at 4 ohms and the subs into one channel at 1 ohm, that would work alot better. Say 125-150rms @1 ohm or something like that?
2 ED 9kv.2 dual 4 ohm ers. The speakers are some fosgate coaxials, like 5 1/4 inchers or something. But now im considering just buying some better front components that will handle the 80 watts from This Amp. Any suggestions? This is kind of a budget deal by the way.
And btw, I appreciate all this help.
Dunerider5
Dunerider5
az
Dunerider5
