whats wrong with my car?
nissanrider06
VooDoo
Ok so my radiator is leaking, i know that but lately when ever i am getting on the highway and accelerating around 55 my car starts shaking, some one said it might be misfiring, it seems like its getting sudden bursts of fuel or something and only happend when accelerating, also when i stop my car sometimes go into neutral and i have to switch into park and into drive again, my car has never over heated becuz i make sure there radiator fluid in there and its not to fast of leak, also i did put in that radiator leak fixer powder which some one said was bad. can anyone help me, since i wont be able to take it in till sunday?
^^ its nothing that major, he would be having a lot more problems if it were something that big.
If your ****** is slipping, youd also notice that, does it only do it at certain times, liek when it goes into a certain gear (if its an automatic) if so, then you need a ****** rebuild, have fun loseing $800
well its like a q uick shake like bursts of fuel or something like someone said misfiring. and my ****** only goes outta gear some times when i stop. and i wouldnt think it was the fuel filter or lines because it onl does it at like 1/2 acceleration when im on like speeds of 45+
Well if it was missing, it would jerk you all around, not just short shakes, it could very well be your fuel filter, your open the throttle body to let more air in, but no gas is getting in there to mix with it, casuseing those short shakes, until enough gas is trying to be forced through the line, to get through that bad filter, i would try the fuel filter first, its going to be your cheapest of all the things listed to get fixed.
Could also be wheel ralated things, probably at the end of the list of possabilities, but you could need new rotors, or just need them turned if you dont want to buy new ones, could need more inner or outer, or both wheel bearings, etc...
nissanrider06
VooDoo
nissanrider06
Eagan, MN
Denial
BP1Fanatic
BP1Fanatic
