whats wrong with my amp???
matt31
i have an infinity betadigital 100 and ive got it pushing a RF HE2 the sub is recommended at 400 watts RMS and when the amp is bridged it puts out 400 watts RMS...the problem is when i turn up the volume the amp shuts down....i kno it has an automatic shut down but i dont get y its doin it??? does ne one kno whats goin on??
im not sure what ohm load im runnin the sub....but ive got 4 gauge wire coming from my battery to a distribution block(i dont kno if thats needed though) then from the block ive got 8 gauge into the amp and also 8 gauge ground wire....how do i kno what ohm load im puttin into the amp???
if it's an he2 its prolly got dual 4 ohm coils....and i'm guessing you are running it in paralell...so your amp is seeing a 2 ohm mono load....if your amp isn't 2 ohm mono stable then it will get to hot and shut down....the only way to cure the prob is to buy an svc 4 ohm sub, or wire your existing sub in 8 ohms....but then your amp will put out half the power at 8 ohms so thats useless, or buy a new amp that is stable down to 2 ohms.
but the amp doesnt really get hot it just shuts down when it starts hittin hard?? like when a song goes quite then all the sudden it hits a really hard bass note it will shut off when i have it turned up...but ur right i think i am runnin a 2 ohm load into the amp and its only stable to 4 ohm so is all i can do is buy another amp??
I really dont see the amp running at 2 ohms killing the amp that quick. I mean I have had a couple of amps that were only 4 ohm stable and I ran them for years at 2 ohms.
I had this problem back a few years ago, dang wish I could remember what it was. Let me think a while hopefully I will remember.
matt31
matt31
richmond,MO
mrmagoo_83
BP1Fanatic
BP1Fanatic
