What's wrong here
neek804
I have this amp
Alpine MRP-M850 Mono subwoofer amplifier 800 watts RMS x 1 at 2 ohms at Crutchfield.com
And 2 of these subs
Pioneer TS-W257D4 (tsw257d4) - 10" Subwoofers - Sonic Electronix
I believe I have them wired correctly to the amp but the problem is when I turn the volume up in my car the subs cut off but the amp is still on
This is how I have them wired to the amp
http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2DVC_4-ohm_mono.jpg
Please help if you can I miss my bass I'm thinking I need another amp
Well if your subs are d4, then you either have it wired to 1 or 4, i'm assuming 1.
That amp isn't stable at 1 ohm.
Solution: New subs different impedence or amp that handles 1 ohm or puts out your power at 4.
I guess I need a stronger amp to push them I checked my ground that's fine..my remote wire kept coming loose from the amp it was too short so I connected more wire to it so I could be long enough
But to be honest could it be the fact that the Ring terminal that's connects to the batter under hood is not really connected properly to the battery I really have it on the fuse box but the rings are not big enough to fit around the positive post on the fuse box so i maybe just take it off till I get a bigger one
neek804
neek804
Richmond,Va
neek804
Mike Mccabe
