well theres only a few places it could go. and I looked at the diagram and I put it where it showed RCA's going toDid you even read teh manual? How do you know you have them in the correct spot?
I bet that they go in the bottom set of pre-outs.. try that and see what happens.well theres only a few places it could go. and I looked at the diagram and I put it where it showed RCA's going to
lol... it is pretty bad.I only got to 1:08 before I saw a problem. I bet the amp goes into protect huh? its cause your speaker wires are touching each other at the terminal. You dont need 8 gauge dude, get smaller wire. That or connect them better with banana plugs.
I was going to mention that too.. Ideally, if everything is correct, you shouldn't even need electrical tape, but for your sake, get some electrical tape, d00d!alright ill try that.
Is duct tape alright to use instead of eletrical? It looks like shit but I dont have any electrical
hey how about relaxing huh?wow find someone to help you it sounds like you dont know what your doing at all.
If its worth doing, its worth doing it right.alright ill try that.
if you could find another place and do as he said with the ground and using a lock washer to stop it from spinning and loosening and causing the ground to arcRca's should go where it says input on the amp.. Don't quote me, but I think it's the left side on the amp. I would also change out your ground, or scrap the paint around the bolt you have it on, and make sure your speaker wires connected @ the terminals on your box are not touching each other.
