J jerseyflipper 10+ year member Member 60 0 Donaldsonville,LA Jan 10, 2007 #1 my friend has an amp that blows the fuse uder the hood but the fuse on the amp is still good wwhat could it be the ground or power Click to read more...
bdawson72 5,000+ posts Finally Has Bass Again 18,444 0 434/804, Virginia 15's:Yezzir Jan 10, 2007 #2 the amp is drawing too much power for the fuse to handle
OP J jerseyflipper 10+ year member Member 60 0 Donaldsonville,LA Jan 10, 2007 Thread Starter #3 what a way tot fix it he has a 25 fuse and he tired 30 also but the wiring is 8 ga. the amp is a bazooka just like the one i had 330 bridge
05fronty 5,000+ posts SALT PETER 11,937 104 conway,ar Jan 10, 2007 #4 none of the power wire is being cut by any metal? did you use a gromet thru the firewall or existing hole?
rangerxtrn 10+ year member SX's Wangin' 92 0 Princeton, WV Jan 10, 2007 #5 what a way tot fix it he has a 25 fuse and he tired 30 also but the wiring is 8 ga. the amp is a bazooka just like the one i had 330 bridge Click to expand... Yea man the fuse is just protecting your wire from overheating from overdraw. I would go get a cheap scosche 4 gauge kit from wal-mart for about 35 bucks it comes with a 100 amp maxi and the wire is "decent".
