bx2005d or xx-hercules?
Ok good good that's what I thought. You get what you pay for yanno, usually the cheaper amp will do worse if they both have the similar specs.
But, my delimma is different. My L7's are built only to run on 2 ohm or .5 ohms, not one ohm which is the best setting for the Herc.
Will the herc still push them nicely at 2 ohms, or should I be looking for a different amp?
hmm, i havent wired my herc up yet its still on the way. Running itat 2 ohms its pushing about 1300RMS correct? I know it can run at .5 ohms, but its gonna be a lotta wattage for the L7's, although im pretty sure they can handle it. I dont have personal experience tho.
Theres amps out there that are a better fit, but if your set on hifonics, it will work.
Hmm, well I'll keep it at 2 ohms unless there is some serious competition lol.
With 650 RMS to each I'm sure they'll thump like a mofo seeing as how that is 100 percent true rated power since this amp is so legendary.
not to change your mind or anything but you could go for a sundown and they are stable down to .5 in the warranty. Just something to think about. Or y don't you get something rated at 2000 x 1 at 2 ohms.
It'll take .5 like a champ... I have one for sale if you are looking for one //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Has been installed but hasn't been used yet as my deck is off being repaired.
FrozenBritches
FrozenBritches
Urich, Missouri.
Fixxer
michigan born
    May 14, 2026
michigan born
    May 14, 2026
