Whats the proper way?
rgnbull1227
NY
I currently have a Kenwood XR-1S powering a JL Audio 10W6 running in 2 ohms. I have 4 Gauge power wire from the battery to the Amp. Now, I am going to add a Kenwood XR-4S running 4 ohms to power my Focals. Question is this. Can I just used the 4 Gauge from the battery to a Dist block and then run 8 gauge to each Amp? Is that sufficient?
Thanks.
You are on the edge with those gauges, but it *may* work if the runs are short. Kenwood recommends 4 awg runs for *each* amp. Either run separate 4 awg to each, or run a 1/0 from batt to distro block and run 4 awg to each amp from the block - to be safe.
i'd say you'll be able to get away with 4 gauge to distro block then 4gauge to amps from the block.
Agree ^^^^. Especially if he can keep the run from batt to distro block as short as possible (mount distro block right at cabin entry point). This would work.
rgnbull1227
rgnbull1227
NY
Jepalan
