Enviouswarlock
Hello i need a little guidance. I have a d3500.5 series mmats and 4 p.30 12" mmats
running at dual 4 ohms and running everything down to 1 ohm. Runs perfect. One small problem i have is after a certain volume
the bass sounds distorted and it i can tell it is not giving its full power. I have 2 gel caps a 250amp alternator and have rated the voltage is not lack of power. I also make sure all the rca's were hooked up correctly.Strange thing is that when i first finished my setup everything was running perfectly after the end of the day this problem came up. What might be the problem, Any guidance will surely help. Thank you
