Whats Fair?
SlapinTheTrunk
I recently bought a sub off of a member on here that is a dual 1. The sub was wired up correctly to have a 2 ohm load. When I first started playing the sub it barely moved, but i thought it was just because i was underpowering it. After less than a minute of play time on low volume, i feel the sub and it is very hot and smells. I didnt know what the problem was so i contacted the seller and asked what was wrong and he asked me if i switched the wires, because he sent me the sub with some wires hanging on it. I said i did because i was wiring it in series and the way he had it wasnt. Then he told me that when the sub was reconed the terminals were switched up on one side and he thought he told me, but he didnt. After he told me that, i wired it up with the switched up terminals and found out that the sub had blown. I am just wondering what is fair. I asked for a refund and i would pay return shipping, but he thinks that is not fair.
edit: I forgot to add that he said that the same thing happened to him, but once he wired it up the right way the sub was fine.
You knew it was reconed? I would have popped the each coil with a 9v batt to see polarity first. I'm undecided on who is wrong here still, it's obvious you hooked it up wrong, and he claims to have told you about the reversed recone issue, so it looks like it's on you.
what you offered is fair if he didn't mention it.. thats like selling an amp with the terminals marked wrong and the buyer blowing it.. not because they wired wrong but because they wired it how it was marked
ur wrong.
the seller thought he told him.. we will see what the seller says.. and any proof of pm's..
yes i can take screen shots of every one, but ill have to do it later because i have to go to work right now. i also told him i wouldnt include his name, because i dont want to bash his rep. i just want more opinions on what is fair.
I've bought tons of subs through the years and i've never checked a single one of them, prolli 90% of us won't check the polarity of the wiring.
IMO if its really like the OP says then the seller is at fault for not telling him that the wires were reversed. Just like another poster said, its like getting an amp and having the ground/power terminals switched and blowing the amp because of it.
if i sell u a used car and didnt tell you that i switched the brake and gas pedals and you bought it thinking it was a normal car and you crashed it soon as u drove it, it wouldnt be ur fault because i didnt tell you they were backwards. and 99% of the time terminals arent backwards!
SlapinTheTrunk
SlapinTheTrunk
Los Angeles
DDSC
