Whats Considered a "Good" Electrical?
If it's that at the battery and not at the amp, your amp wiring is inadequate. Probably on the ground side.
I didn't check it yet I was just asking if there should be a difference do to the lenth of power wire.
Would that be at the battery or amps? Just wondering.
should be at both. if you drop more at the amp than the battery there is something going on as helotaxi said. now remember you dont have to do what im saying, i just said 13.5 because IMO, a "good" electrical system is one that hardly fluctuates when being taxed.
to the OP, if you're going to just add 3-400 watts i wouldnt waste your time. if you're going to upgrade why not at least double your power? much more likely to have an "audible" gain this way (that is worthwhile at least) by doubling power than by adding just a couple hundred watts. just my .02c
-200 Amp Mean-Green Alternator (Benched @218amps)
-Double 1/0 Big3
-Optima D34 YT under the hood. Triple 1/0 frame grounds.
-Triple 1/0 positive runs to rear.
-Three Optima D31T Yellow Tops. Triple 1/0 frame grounds.
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif.
nG
im running a pair of Kinetik HC2400s
a custom large case 300A Excessive Amperage Alternator and lots of1/0
i consider it to be good.....my voltage never drops below 13v and i have a 40.1 and a pair of MTs and a DLS A4
A good electrical consists of stailizing voltage, which requiers amprage.The ideal setup would have voltage droping no more then a few thenths a volt a full output.To do this it usually requiers a bank of batteries and a HO alt with lots of wiring to flow current witout much resistance.
JLMaster
JLMaster
Jackson, Ms.
PSturmer
