what x-over do i need
king ranch
Banned
http://cgi.ebay.com/PAIR-300-W-PIEZO-TWEETER-DRIVERS-FOR-PA-DJ-HORN-NTD300_W0QQitemZ360081656379QQihZ023QQcategoryZ47092QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/2-New-Quality-Bullet-Piezo-Tweeter-Horn-Driver-Speakers_W0QQitemZ220273341336QQihZ012QQcategoryZ3276QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
i already have the horns just need the drivers whats the better set i know both are cheap but this is for just a little project gonna run them on a sony xplod amp
so wat exactly do i need to prevent the freqs going to the drivers that it cant play
thanks
Those are both absolute crap. Get a real set of tweeters or horns from PartsExpress.
You can't just swap x-overs around like baseball cards into any set of speakers. For a new set of drivers like your doing I suggest seperate HP and LP filters for each driver rather than a unified 2 way x-over. Pick a x-over freq well within the frequency range of both drivers. Probably around 2 KHz. The filters must be chosen to match the impedence of the drivers, and then you may need to add a pad to the horn to match the levels better.
well wat xover do i need for those seleniums and i am putting them on my flats boat under the polling platform so i can hear music while running full throttle
well the amp i am gonna use is a cheap xplod amp only has a lp and a off setting so if i turn it to off then i cant adjust the freq to the seleniums so i need something to prevent low freq's
well i can just turn the gain down they dont need much to get loud i heard
You use a passive High Pass filter on the horns to block the bass. You use a passive Low Pass filter on the woofer to block the highs. You need a pad on the horn to reduce the power of the horn compared to the woofer or it will sound like a tin can with no bass.
i thought these horns are for only highs vocal range basically i dont want any bass from it period just vocals, i will have mids for midbass and a 12" sub
king ranch
Banned
king ranch
fl
king ranch
