What wrong with bluetooth audio.....
wondering.... wouldn't this all be dependent on the recording first? wouldn't some sort of lossless format be better to start with? I have an Alpine BT radio at work that plays from my iPhone via BT just fine. I can't hear or measure a difference in any sound between BT and 3.5mm.
For what it's worth all my attempts started from same recording, then I used the different applications to play through the radio. Iphone to USB has very noticeable poor quality.
USB cable to phone does not count as a digital signal unless you have a digital to analog converter overriding apple's internal DAC, it might as well have the same quality as an auxiliary chord. Just use flash drives instead.
USB cable to phone does not count as a digital signal unless you have a Digital audio codec overriding apple's internal DAC, it might as well have the same quality as an auxiliary chord. Just use flash drives instead.
Hey i'm starting to learn a few things about this, thanks for the reply. Do people do this, is it common? Link to what I need to override the DAC in the phone? My local stereo shop said I needed some type of proprietary wiring thing to the back of the head unit, I don't know wtf he was talking about.
not sure if your head unit is capable of doing what he's talking about but neo_styles already answered some ways of doing it
Because the internal DACs on iDevices are pretty much crap. There's a list on Crutchfield of all the 2012-13 units that have iPod DAC bypasses (80PRS and a bunch of other models are on there). Or you can spend $100 and get a Pure i20 which features a beast of a DAC and iPod bypass. Try to find the units with Burr-Brown or Wolfson DACs at resolutions of 24-bit or higher.
AL210
AL210
PA
calebkhill
vegang
vegang
