what would get louder?
Redgp
I got 4k watts to play with and about 3.5 cu ft of space. My dilema is should I get 2 hdc3 10's or a single dc level 5 sub probably a 15 since i can get the cu space for it. What would get louder and impress more ppl 2 10s or a single 15?
id take the 15
The level 5s for sure. If you can get that 15 a little more space, then do that. The 10s will be loud, sure, but that 15 is a SPL woofer and as such likes small boxes. Plus, the 15 will have more cone area than the 2 10s anyway, use that to your advantage.
I said either a 15 or 2 10s because theyre around the same price. The 15 will take up more space which on their site is says 3.5 cu ft and the 10s like 1.2-1.5 so i can make a smaller box with the 10s but dont know if itll be louder that way. Another thing my vehicle is a hatchback which will help a lot
Not a whole lot of info on the dc level 5 subs online. Maybe it's because not a whole lot of ppl have them. Anybody reading this have a 15 right now that can tell me what size box theyre using?
iso load them
Isobaric loading is to this day the stupidest use of two speaker drivers. I cannot think of a single reason to use them over one. They aren't louder than one, and while they take up less space, you're paying 2x the money for a slightly smaller enclosure.
What vehicle? It makes a big difference //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
2 18's in a s10 below window line is not as loud as 3 15's below window line. Sometimes less cone area is better
Yes, I have a difference, but my difference is HUGE. The difference can be so big, as if I had a sound system in about 150-200 dolars (with wires...
41
9K
im not looking to seal off im trying to stay out of wall classes and plan on staying in trunk classes
15
What are some of the louder, while still sounding good, 6.5" sets out there? Been looking at some of these higher powered Sky High Car Audio sets...
My subs unload at full tilt @ 28 hz, They are in 3.69 cubes net tuned to 34 hz. 4 - 8's. Big box and big power.
Redgp
Redgp
Tucson, AZ
Redgp
    May 18, 2024
    May 18, 2024
