What would cause magnets to slip?
geonfreaq
May be kind of hard to see but Im wondering if this may be part of all my troubles I had...
Have you dropped or bumped the motor hard?
That or they did not use enough glue when they built it.
Nope. Its been installed for a year now but Im guessing being installed in a truck that goes off road could cause this king of damage.
Yep, looks like you have a shifted motor.
Im guessing a shifted motor like this would cause the VC to change and cause the amp to see some strange loads?
I could explain it to you but it's not like you actually care...
Thats why I thought my answer would work haha
Shifted motor = locking of the voice coil in the gap. I dont know if it would cause any impedence change as I've never had it happen. But I do know that your sub is most likely screwed. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif You can get someone to fix the shifted motor and recone it though
I dont know if thats worth reconing. A RE SX is only worth but so much haha
SX's are notorious for shifting. No, when your pole piece or top plate shift, your sub doesnt move. This happened recently. The magnets are physically pinching the coil in between the magnet itself and the pole piece. You could send it in to get fixed but ur better off donating it to SPLaudio or somethin lol
How is it that I make a comical reply in my own thread and it gets deleted but the "BS" post I reply to doesnt? Thats funny...
Anyway, is it worth saving the motor and using the parts to build a beefier sub? Ive never had a custom sub //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
You need something more like a pro audio woofer. You want a really light Mms with a lower Fs. Idk how much loudness vs range you want, but a...
14
Not a term, a description. When it clips, it sends a distorted signal (current) through. A square wave contains more energy than a sine wave and...
27
"large crimping tool" hammer or hydraulic? Seat bracket bolts aren't good. The seat brackets are usually completely painted and so are the...
I don't think so, it is the standard radio/speaker combo that comes from factory, but I will do some research to make sure there isn't one hidden...
956
geonfreaq
geonfreaq
norfolk, VA
Fi Car Audio
    May 31, 2024
    May 24, 2024
