geonfreaq 10+ year member
May be kind of hard to see but Im wondering if this may be part of all my troubles I had...
I could explain it to you but it's not like you actually care...reverse magnetic field? magnets, how the hell do they work??
Nope. Its been installed for a year now but Im guessing being installed in a truck that goes off road could cause this king of damage.Have you dropped or bumped the motor hard?
That or they did not use enough glue when they built it.
Im guessing a shifted motor like this would cause the VC to change and cause the amp to see some strange loads?Yep, looks like you have a shifted motor.
Thats why I thought my answer would work hahaI could explain it to you but it's not like you actually care...
I dont know if thats worth reconing. A RE SX is only worth but so much hahaShifted motor = locking of the voice coil in the gap. I dont know if it would cause any impedence change as I've never had it happen. But I do know that your sub is most likely screwed. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif You can get someone to fix the shifted motor and recone it though
