What will I need to upgrade?
Human Being
7
I've looked around to try and find a definitive answer to this but couldn't, so I will ask.
Currently I'm running 2 12" mtx terminator subs on 700wrms at 2 ohms. I've done some looking around and decided that I want to run 2 Sundown sa-12s at 0.5 ohm on a saz-1500d.. What (if any) upgrades will I need to make to my car's electrical system to do this properly? Currently running a stock 105a alternator with 4 gauge power wire to my amp.
Kind of looking for the cheapest way to run this setup safely.. On a budget and I don't have much experience so recommendations would be greatly appreciated
Lack of experience I suppose. What would you recommend? My first plan was just to run a sax 1200d at 1 ohm with the two sa-12s.
That's not a bad idea. No reason to run at .5. The sa's can take some power though I would recommend a 1500 at 1 ohm on them. There is a couple in the classifieds right now for a good price.
Ithink that sounds good. Im not sure what im going to need to upgrade electrically. it doesn't seem like too much power so i don't wanna go over
board
just adding another battery might not be the right move. Alternator is going to have to work overtime to charge both batt's which causes premature failure. I would do a HO alt and upgrade batt under hood.
Yeah that's what I thought but I don't know if I would need a H/O alternator for only 1500 watts.. they seem to be pretty expensive.
Buy my two Sundown SA12's and Hifonics BRZ1700, I have a 47 AH optima battery under the hood and Big 3 in 0 gauge for electrical and the setup runs just dandy. Depending how how powerful your alternator is... you should be fine running 1500 watts.
Human Being
Human Being
plantinseeds
