What type of screws 2 secure Sub
Just got done making a box for my 12" Alpine R but wanted to know what was the best way to secure the sub to the box. Regular screws or is there something new that is works great. Thanks
regular screws are fine, as long as they aren't too big, and make sure to pre-drill the holes so you don't split the MDF
T nuts would work best.
R those T-nuts coo to use? arnt they hard to seat on the MDF wood?
Thanks all:)
No, you just have to pre-drill a hole big enough so that the shaft part slids in place easily. I wouldn't say these are always necessary, but they do hold stronger than screws in wood, and make it possible to install and remove the sub multiple times without damaging the wood.
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=260-778
Do those tabs sink in ok or do I need to use a c-clamp or pliers to get them in??
I think Im going to use those.
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
in MDF they are tough to get in and you'll flatten the teeth on a few. I put glue into the hole as I tighten them to be sure I can get the screws back out. //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
s_krillin
s_krillin
Stockton, Ca
AudioAnonymous
