What Type of Numbers do you think I could hit with this set up???
my 2 cents: get rid of the cap.
also you'll get 1db.
that's all //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
reallly! You would gain about 1DB without the cap...? More resistance on everything I suppose. I like it because it looks good.
no... I just meant you'll hit 1db with that setup.. was sarcasm there.. BUT get rid of it anyhow.. just more strain on electrical than help.
Run the Pups and it'll blow away any system you've heard or ever will hear.
But really though ditch the cap and build a stout enclosure, lows 140s+ shouldn't be any problem at all.
150+ with some work.
L7s are very very underrated in the SPL world... With sum knowledge, building skills, and patience big numbers can be put up. My brother ran 2 15" L7s of an RF 3000BD in 9ft3 @ 34hz w/ 105sq in of port and it did a 150.? @ the dash(Termlab, all sealed up).
Bassraced a 148.? also. It took a ton of bracing, 1" MDF(double baffled), a ton of resin, and 2 8" aeros.
I've seen two 15" L7's do a 153.6 at the headrest in a CRX. I've also seen 6 12" L7's do a 156 @ the headrest with 4 Cactus Sounds 5kW's in the back of a Mountaineer. They can get loud with some work.
I would be happy with that. IYO is there a big sound difference between a 130DB system and a 140 DB system?
theoretically 3db takes double the power so to the ear 10db (130 to 140) is gonna be very apparent to you lolz.
I wouldnt be surprised if it hits mid 40's on music as long as the enclosure it right.
ya you should be louder than 130 with what you have now.i was in the 140range with 1 l5 15 ported on 1200 watts on music.but i dont know if you got room to go ported in a trunk car.if you do with 2 L7 15s you should be very loud for street beatin. 140's all day.good luck with build.
*Honda*Bass*
*Honda*Bass*
*Honda*Bass*
Whitewater WI
30hrtz
