what type of boxs for 3 12's
  • Thread starter pfunk358
  • Start date
  • Replies 3
  • Views 2K
P
pfunk358
Guest
I have three 12" rockford power hx2 i'm gonna have 2 bridged on the bd1500.1 and the other on the 1000a2 ... should i go with a ported or sealed box... will the ported be that much louder to sacrifice soud quality..
thanks
Firstly, I hope that you are planning on keeping the speakers all in separate chambers.- especially if you are going to be running dual amps. Two amps powering subs in 1 enclosure will likely produce quite a bit of cancelation unless you have equal power and the gains set exactly the same on both amps.
As A general rule- a ported enclosure will give you approximately 3db more output that a sealed encloure in most applications. However, some of the tight- punch of SQ will be lost and more lower "boomy" response obtained. On the other hand.----> 2 subs in a sealed enclosure in the right location can also produce an extra 3db of output and retain thier accuracy and SQ, and still hit hard.
Kinda a personal choice- your ears should make the ultimate decision.
take it easy,
-zane
716
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
825
Dammned that looks awesome. be a great picture in a workshop!! I have maybe 6 steel ratcheting type clamps, if that. much like the ones you have...
888
If you want something weather resistant, get a marine amplifier.
Guest
zane
