What to tune box to?
I don't believe it. My subs bump harder than you homie. Get your 12 apline type r subs out of here. I had that and then I bought these SSA.
****, and I have the right to talk crap. You know why? Cuz I'm a producer. I make beats for your system to bump.
I drive an Ion redline. I can tell you there is no possible way for you to get that box in your trunk unless you start cutting the rear end of your car apart. Pro rabbit built me a box for a single 15 using 34" wide, 17" tall, 17" depth. These are the max dimensions without using fractions that you'll be able to fit in there. I also had to remove my trunk latch to get it in.
Best bet is to sell the box you currently have and let pro rabbit to build you one. See if he has the old design that he used for mine. It was tuned at 31 hz and with my custom TC 15 i was doing great down to 26 hz. Shouldnt be too bad with your SSA sub.
Best bet is to sell the box and have pro rabbit to build you one. See if he has the old design that he used for mine. It was tuned at 31 hz and with my custom TC 15 i was doing great down to 26 hz.
Did u not read what I said? I just told u I did. If you want I can send you a pic
Send me a pic of what? And told me what? I've only posted in this topic ONCE. How have you told me something before when I've only just now posted? I told you what your options are, and there really is no other way around it unless you cut your trunk apart.
Dogg, I didn't cut my trunk. To fit that box in I took out the piece that locks the trunk when you shut it, took out the carpet and everything under it (Spare tire and all that crap) then put it right in. Like I said, if you want, I'll take a pic of this box sitting in my Ion 2's trunk.
oh didn't really read all the posts. idk my opening is nowhere near big enough to fit a box that big through. It was hard enough getting the box I had in
And why the **** are you going to best buy for your ****?
Because I don't know how to wire my subs, how to set the gains, phase checking, etc. They said they do it all for $20.
But I'm sure we have the same sized trunks. It's just a ***** to get it in. Took me 2 hours to figure it out and get it in.
All this info can easily be found from a 5 minute google search. And trust me, 95% of this forum has a better system than you. And for the record, a pair of Alpine type Rs properly ported on the same power would most definitely be louder than your single 15.
Tried Google and failed. I need hands on teaching.
Nah I had Type R's 12's properly ported, boxed, u name it. They were whack! When I played them too high they stopped playing. And made some faint rattling noise. Whack!
I think the majority of you miss the obvious troll here. Now, please lets keep trolling to the Dome. As per the rules this is tech not the dome thus trolling will cease. Regardless of what is posted we know what is fictional or not. Just let it go.
Well, at least in this thread it will.
Pumper
Pumper
Denver, co
RAM_Designs
