What to look for used subs
What setting would it be
Sent from my SM-G955U using Tapatalk
If they give a bad reading is it difficult to repair? He doesn't have anything to try on so if the reading is good that means they should work Correct
Just as popwarhomie said, set DMM at 200 ohms. Stick probe in each pos(red) and neg(black) of the terminal of the sub. Should give you a lower number if the subs are dual 4 ohm, then it might read 3.7 or 3.6 There's never a perfect 4.0 coil read.
Same with dual 2 ohms. So the DMM should say 1.7 or so give or take a point or two. Let us know how it goes.
I just picked them up the lowes reading I got was 3.6 so I got them. Now just need to figure out the dimensions for a box and build one
Chalo_209
Chalo_209
Kingsport tn
Boomin_tahoe
