I really like the RL-s too. I think the decision will be between a pair of the new Mags, the RL-s, or the Aura.http://www.partsexpress.com/webpage.cfm?&Webpage_ID=3&filter=reference-22008
these dayton HO or HFs look like they might do well IB. only $119
some rl-is would be sweet
If I do this, it will be a true IB install in an Avalanche. The baffle will replace the midgate.Qts = Qtc for IB. You can use a driver with a medium to high Qts (~0.4 to 0.8), low Fs and high excursion. Of course, this assumes you have a very large cavity you are placing the driver in. Otherwise, it becomes a large sealed enclosure with leaks.
The IXL-18 was built primarily for this purpose, which is why you don't see too many of them in car installs.
x2...Qts = Qtc for IB. You can use a driver with a medium to high Qts (~0.4 to 0.8), low Fs and high excursion. Of course, this assumes you have a very large cavity you are placing the driver in. Otherwise, it becomes a large sealed enclosure with leaks.
