What size fuse?
agarabaghi
I have 2 amps (identical) with 4x30 built in fuses, what size fuse should I run at my distribution block?
I'm running 0/1 awg from the battery to a knu distro that splits it into 2 4awg which each have thier own anl fuse.
130amp for each or 150?
u fuse to protect the wire not the amp . fuse for wire maximum amperage carrying capabilty...so if its 1/0cca use 250 if its 1/0ofc use 300
all the wire is OFC... how come so much higher on the OFC?
Because pure copper wire can carry more amperage....so 150 on 4ga and 300on 1/0
---------- Post added at 09:14 AM ---------- Previous post was at 09:13 AM ----------
Aluminum is not as conductive as copper
Fuse anything going to the battery 150amp fuse I would do. if it shorts you saved your battery, and than you look for causes why it happen, if...
Same here. Its what my search pulls up, but its all over the place
950
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
Tesla beat Edison. Why do you think we transmit high voltage ac? Cars are low voltage dc, which is absolute worst as far as efficiency goes, but...
61
agarabaghi
agarabaghi
Orlando, FL
agarabaghi
    May 31, 2024
    May 24, 2024
