what size fuse for my amps please
riddla
nf
Ok, I have not checked the fuses yet but i will be running 3 amps, 1 for bass, 1 for mid, 1 for treble active setup. My question is do I add up all the fuses ie 60 x 3 = 180 and then put the total of the sum 180 to the main fuse from the battery if im making sense just as an example please ?
the fuse holder currently has a 150 amp fuse in it
im just trying to find out what size fuse i need, im not sure if my original question is the way to do it ?
ok, this is what im using. Im using a fuse from the battery fitted with a 150amp fuse going to a 4 way distribution block as im running three amps. each fuse in the distribution block is 60amps.
Is this ok or am i asking for trouble please
riddla
riddla
nf
riddla
michigan born
    May 14, 2026
michigan born
    May 14, 2026
