What size fuse for big 3?
My amp is putting out the 600 rms @ 1 ohm and on the amp I have 2 35A fuses. What size fuse should I use for the power wire to the amp? Is it ok to use a 100A fuse for my alternator then? Since its putting out 90 amps? Thanks.
I also upgraded my "BIG 3" using 4 ga. cable. I did a lot or research on what fuse to use and I found out that the max fuse rating is 150 ampere rating. That is what I'm using now.
The fuse is to protect the alternator from being "FRIED." French Fries anyone...lol
Hope this helps
the fuse has little to do with size of wire but more of what your amp puts out. if yours is 90 you want something over 90 so if there is a jump in amperage the fuse will trip
100% incorrect buddy... The wire size has EVERYTHING to do with the fuse size. 120-150A would be fine for 4 guage wiring.
I do suggest using at least 1/0 awg wiring for the Big Three, anything else and you are wasting your time...
you really dont need a fuse on a 90amp alternator using 4ga i mean its even optional but recomended if you use 1/0ga so if your using 4ga you dont need to fuse it. Only if you want to. Read the Big three article
Anything over stock is a improvment most cars come with 8ga so even using 4ga is an improvement but like most people say since your doing all the work you might as well do it right the first time and go big
MOST....mine came with 4 gauge stock...
RollinRemz05
RollinRemz05
Toms River, NJ
Ruffy
