What size box for AQ SDC2.5 10?
swollen_cu
I tried to look up some optimal enclosure sizes for a single sdc2.5 10" but couldn't find any answers..
I was looking at the free box diagrams in the stick section and I was thinking 2.0 cubic feet at 31 hz. Do you think this would be too big for the sub?
Any help would be appreciated...
It's gonna be running off of a AQ1200D fyi.
Just from the AQ site, which i would follow:
Audioque subs have been designed to extract max performance from moderate box volumes. The 10-inch subs work in 1.2-1.5 net cuft, 12-inch subs work in 1.8-2.5 net cuft, and 15-inch subs work in 3.0-4.5 net cuft.
If you want a personalized box, just email DJ at audioque and ask him what the best box will be for it. I did that a while ago before I even ordered my woofer, and he pointed out everything that I needed. Port width, length, dimensions of the box to fit the space I had, etc.
SWEET! thanks bro! Ill probably build a 1.5 cubic foot box just to maximize space.
Remember it's 1.5cf net. So you have to build a bigger box to accomodate the sub displacement & the port
Yeah I know. Thanks for the heads up though!
You have more power than you need, so I'd use a slightly smaller box so you can put that power to use...1.25ft^3 at 35hz seems about right.
I was thinking the same thing... I didnt want to use too big of a box with that much power running to it. I heard its easy to blow subs that way.
So this box plan would probably be the best one to use?
1.25 @ 32hz
swollen_cu
swollen_cu
New Orleans
Buck
