what size box for a jl 12w0 and bazooka rsw1224dvc
  • 2
bigredcrew
i've been going through some of my old stereo stuff that i had stored away. i found a brand new original jl 12w0 and an almost new bazooka rsw1224dvc 12" sub. I would like to build an enclosure for both of them to mess around with them. i'm thinking ported. but not sure what size would work good. can anyone help with the sizes?
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
40-85l is about the size range most high powered 12" woofers will want for a box. You should use manufacturer suggested box specs unless someone...
I would like to a bandpass box wherein the subs are facing each other and each have their own sealed enclosure with the center section being the...
Try the sealed then. If you feel you're lacking low end extension you might try to build a ported box to give you a little more output down low.
bigredcrew
bigredcrew
Latrobe, PA
DBfan187
saints747
    May 7, 2024
saints747
    May 7, 2024
