What should my crossovers be set out?
  • 4
The_Grimy_One
Phoenix, AZ
So I have a 12" iDMax sealed in the optimal enclosure. It hits real hard, especially for only throwing 600 watts rms at it. I am curious, though, what the crossover should be set at. I have the low crossover @ 80Hz and the subsonic (high crossover) @10Hz. I feel like I am missing some low end, though. My amp knob is messed up on the high crossover section, (I have the new Leviathan II), so I am going to meet Stephen Mantz in a couple weeks to have it fixed. I am not sure if this has something to do with it. I just feel on some songs, which I listen to a lot of rap, it is missing some of the low notes. Maybe around the 30Hz and lower area, sorry not really good at listening to frequencies, (I am just guessing). Any suggestions would be welcome, thanks.
The sub xover depends on your front stage.
The point is to blend the subs with the mids.
Try moving the xover higher than 80hz, it sounds like you might have a hole in the response where the mids arent putting out much near your current xover point.
If you're missing bass in the lower frequencies (like 30 hz), you might want to try a port enclosure, or a t-line. Sealed boxes usually don't reproduce lower frequencies very well, I don't think it has anything to do with your crossovers.
---------- Post added at 10:20 PM ---------- Previous post was at 10:20 PM ----------
I mean ported enclosure.
Thanks for the responses guys. I will try that, and yea I think ported may be what I need to do. I love sealed, but the extra SPL would be nice.
The CT's are nice, That Sundown is a a frik'n beast!
723
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
636
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
728
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
The_Grimy_One
The_Grimy_One
Phoenix, AZ
The_Grimy_One
    May 18, 2024
    May 18, 2024
