What should i do?
well, those subs are rated at 125@4ohm watts RMS. so after you put both into the box, you'll wire them in something called PARALELL.. so both of these subs will become a 2 ohm load. this will increase the power they would recieve drastically.. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
well, where we live, we don't really have A LOT of choices to choose from.
go for JBL
or look into buying a JBL amp, they rock for the price //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
here's a 2 channel amp:
http://www.epinions.com/615028_JBL_180W_x_2_P180_2/display_~latest_prices
it is 180 watts x 2 at 2 ohms .. youll run your subs @ 2 ohms, so they'd recieve 180W each. and i read a review in CARSOUND.COM about this amp, and it said it,
"The P180.2 performed quite well during our testing session, meeting, and in most cases exceeding, its published specs."
Yes they one have one channel. You just wire your subs together in parrallel or series and you are only gonna need one channel //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
As long as they are the Comps and not the CompVR's, a 300.1 would do the job just fine. Depending on the space you have, you might also consider a single 12" CompVR ported and the 300.1, I think it would spank the 10" Comps for about $275 total.
a ported 12" KickerCompVR probably would do spl better, and it would be cheaper.
but it all depends on what my friend wants. and we don't know how to make ported boxes really, like how to tune them. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif DAM TUNING!
or wait, do sealed boxes need to be tuned? or is that only bandpass
The CT's are nice, That Sundown is a a frik'n beast!
949
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
774
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
906
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
Arn
Arn
Canada
more_spl
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
