What should i do 4 speakers
With only HU power, go with co-axials. Also, your HU will do no where near 50w RMS. Expect more like 12-18w RMS out of it.
Anyways....look into any reputable brand; Boston Acoustics, Focal, Alpine, Eclipse, etc etc. Just go down to your local shops and listen to what they have on the sound board to get an idea of what you personally like the sound of.
If you want to go with components, then an amp would be worth it. However, with only $200, you would be much better going with quality co-axials anyways. With only $200, a quality amp and comp set is pretty close to being out of reach once you consider the extra wiring that would be necessary....and it would also eliminate the possibility of being able to afford rear speakers (if that matters to ya, but with a properly powered comp set in front, rears wouldn't be needed anyways).
ryanbssc29
ryanbssc29
Waveland, MS
squeak9798
