audio_phill
Walking TSP Encyclopedia
lol, 6.125 is def tc2+ lol. Keep in mind I go through 150+ subs a year man, hard to keep all details in check lol.
I've had them rip through stamped frames and never had one break, had a few that were crooked that couldn't be used, but never a fail.You dont have any issues with them breaking? They hold solid in the MDF?
That be the one. DVC3 ohm sub. My motor isnt as shiny as yours, but Ive read thats an issue with the TC motors is that they like to tarnish over time.
Sink the Hurricane nuts into their holes and then use a Dremel with a grinding bit to shave the flange.Those wont work with my sub or box. The mounting holes on the Evo are very close to the edge. After getting those Hurricane nuts in there I wouldnt be able to get the sub out. The motor would get stuck on them.
Dont have a dremel.Sink the Hurricane nuts into their holes and then use a Dremel with a grinding bit to shave the flange.
I wont. I just want to make sure they are going to hold in the MDF tightly without stripping out.dude i HIGHLY doubt ur gonna have issues breaking those oxide screws.lol. they're pretty beefy. and ive used straight up drywall screws to hold in my HDC3 15 (mounted vertically mind you) on 1500 and never even broke one of those.lol. the oxide ones are about twice the thickness of drywall screws.
Don't you want to put them in from the back side anyways, so as you tighten the bolt you're also ******* the nut tight up to the MDF? I heard using some adhesive with those nuts will keep them from ever wanting to slip out, like I have heard of them doing before.Sink the Hurricane nuts into their holes and then use a Dremel with a grinding bit to shave the flange.
