What Ohm is this configuration?
Scar13
If I have 2, 4ohm speakers and on one set I run speaker one positive to speaker 2 positive and negative to negative and run one set of positive and neg to my amp isnt that a 2 ohm load?
so SPeaker 1 positive to speaker 2 positive and the same on the negative, then run one set of + and - from speaker 2 to my amp..
I believe this is a 2 ohm load..
I cant find my old ohm configuration guides anymore DOH!
EDIT..
Nm I remember this is running them in parrellel and is indeed a 2 ohm load..
**** YOU AUTO SOUND!!!
Whats worse is I can not re wire them due to the fact of there location.. I will have to send it back for them to retake apart grrr.
wait a moment..
So my amp will see a 2 ohm load, but each speaker will get half of the load correct??
SO a KX600.4 will see a 2 ohm load and kick out 150Watts, but each speaker willg et 75 watts. ??
Scar13
Scar13
Dallas
Scar13
