Do you have any idea what you are talking about? I sure have no idea what you are going on about. If you don't understand the difference between series and parallel wiring and the effect that each has on the final load then you probably need to learn.
As for your last post, it is physically impossible to wire 2 DVC 2ohm subs to a 1 ohm load. It would seem that you are trying to wire 2 4 ohm DVC subs to a 1 ohm load. If you have them wired lik the drawing posted earlier in this post or like the drawing second on the left in the JL tutorial, then you have them wired for a 4 ohm load. If you want 1 ohm, connect all the positive terminals (both coils of both subs) to a positive amp terminal and do the same on the negative side. That will give you a 1 ohm load.
