what kinda amp???
Type: Subwoofer
Driver Diameter: 12
Power Range (watts RMS): 150-400
Impedance (ohms): 4 (SVC) 2/8 (DVC)
Primary Mounting Locations: Sealed Box
Sensitivity w/2.83-V input @ 1 meter (dB SPL): 90/93
Freq,. Response (±3dB): 23Hz-250Hz
your welcome //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
actually theyll take a bit more than 400w a peice,but thats a good starting point
something like a MTX 1501D which would do around 1500w@2ohm,or the Tantrum which is discountinued and very hard to find - search out amps that make full power at 2ohm,
1500+watts - some early RFs too
If you got the money, a Digital Design M1 would do the trick. Two of them strapped together wired down to a 0.75 ohm load will get you roughly 1500 watts each. //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
budgrove
budgrove
Johnstown, PA
Spooby
NorthFramingham
    Jun 30, 2026
