this is why arguements get started on this forum... the question was not "is there a 15 that is just as responsive as another 10" because yes there are 18's of some brands that have quicker response than some 10's...Who says a 15 can't be as responsive or even more responsive than a ten inch.
i've heard this arguement too... while part of it is true, whats assumed here is that if you put a 40 hz signal into the sub it is going to play that signal exactly as it is put in... not all subs do... if that(^^^) was all there is to it then there would be no reason to buy one sub over the other other than for volume... and i think we all know that's not the case...there was a thread in here that explained why dif sized subs respond the same i cant find it .. i searched just now
it has somethign to do with ... if the song is playign at 40htz that means the woofer is. if the woofer moved slower it wouldnt be playing 40htz and hwould mess up the song 40 cylces per second is 40 cylces per second
true they have more mass to move, but it still moves at 40 cycles per second
something like that .. if someone smarter chimes in they might know where the thread is or how to exlain it better/more in depth
yeah i take back what i said about smaller subs having quicker responce somewhat but it does effect the sound in some installationsi used to listen to heavy metal all the time when i had my 15"'s and it sounded perfect. a 15 will give you a pretty heavy sound. if u run 1 or 2 run them in a sealed box
