pro-rabbit
Moderator
dbl post //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Go here thorbros.com | This ain't no **** corporation...., they have everything and anything you need to bag your s10. As everyone has said, it's super easy to bag an s10, even easier if you get a bolt on kit. Last one I worked on took me 2 days, and that's because we knocked off early the first day.ok rabbit i guess its a matter of the cost of the complete kit , i know the s10 forum is no much help and the responses are slow is there a special kit u use or buy ?
No, you need a link system, would recommend a 4 link with bag on lower bars or over axle, and a step notch for the back as well. Can you weld?so something like this is all i need ?Airlift LifeStyle Manual Air Management System with 4 Dominator Bags (2 Gallon Tank) | thorbros.com
You need a link system, notches, 4 bags, at least 4 valves, though I would recommend atleast 6 so you cut down on body roll n the back, a tank, a compressor, and all of your airlines and wiring. Would also recommend gauges at each valve as well as tank. Might be forgetting something here as I am dead tired, if I am, I'll come back and edit.yeah i can weld but the bolt on looks alot easier ,dam so this is alot of things need so for a better idea of the total pricing i need the bolt on kit and then the bag system kit ? im lost on what exactly is needed to buy or plan on buying
Water trap and a check valve would be ideal.You need a link system, notches, 4 bags, at least 4 valves, though I would recommend atleast 6 so you cut down on body roll n the back, a tank, a compressor, and all of your airlines and wiring. Would also recommend gauges at each valve as well as tank. Might be forgetting something here as I am dead tired, if I am, I'll come back and edit.
