What i've been up too... Dual Folded horn done by Toxic Bass for Fattony911
yeha, ok, you can call it a horn if you want, but dont expect it to have much output below 50Hz, or much more gain than a 6th order bandpass enclosure...
Thats what he said....i would just keep him on ignore. That looks sweet as hell. I cant wait to see the inish product.
you already said that.
no I didn't...
the horn signal path is like 50inches long... thats 127cm... thats HALF what it needs to be to get ANY kind of output... not to mention that the mouth is once again half the area it needs to be to get any gain, it WILL act very much like a ported box... //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
ah well, atleast there wont be any port noise //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
if it has any output below 50Hz, its because its just acting as a large flared port, and wont be boosting the output at all...
unless u designed that box..u really cant say that
we all dont know what that box is tuned to..if pete designed it more than likely its going to hit the lows well
idont think he designs boxes..especially 2 15's to hit hard in the 50hz and up range...being that the subs being used sux and those freqs i know it was designed to play down low
80
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
Thinking of going this year. Around August maybe? Never flown before and I know nothing about flights. Any tips on when is best time to buy...
My 1964 fender vibroverb. It’s a tube amp for guitar. It has broken many times. But it is a serviceable amp. I can fix it.
73
14K
This place used to be thriving. This place has changed much like the hobby. The brick and mortar stores are phasing out leaving no one to host...
19
4K
iamamp3pimp
Bass Heads Entertainment
iamamp3pimp
Tampa FL
atlninja82
