Rootus
I have a very simple setup -- one amplifier, an Infinity 7541a. Two door speakers, Polk db6500's. And a Kicker Solo-Baric S8L54 subwoofer. It is not yet installed, my intention is to create a custom sealed box for it and put it under the passenger seat.
The issue -- the subwoofer is the 4-ohm version (DVC), but my amp is a 2-ohm amp. The manual for the 7541a says minimum impedance when bridging two channels is 4-ohm, so I've got a choice between running the subwoofer at twice the recommended impedance, or half of it.
First question -- what is the real, practical effect of using an 8-ohm subwoofer with an amp which is rated at 278W RMS for 4-ohms? I suspect it is not so simple as "half."
Second question -- would it even work if I wired it at 2-ohms? Someone suggested that to me, "wire it as 2-ohm, don't crank the gain up." But I'm thinking the amp has probably got a protection feature that would detect the low impedance.
Third question -- How much is enough? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Okay, that was a loaded question. With a bit more detail, perhaps I can get some good guesses. I am looking for enough bass to match the output of the db6500's. I do not crank the db6500's up until my ears bleed, although they seem to be able to do it -- all I want is something that can overpower road noise at 75 mph (which can be considerable in an STI), so that I can enjoy the music. I do not desire to share my music with my neighbors or anyone else, and I like my hearing. Given this, and the fact that I'm going to put the subwoofer inside the passenger compartment instead of in the trunk, it has been suggested to me that even if I only got 139W of clean, honest power, I would likely be more than satisfied. There is a lot of subjectivity there, but does anybody have any thoughts on this?
I am trying to improve my understanding of how this all works. It seems to me that an amp doesn't have any inherent limit on how much power it can produce -- more like it has a practical limit if you don't want to overheat it or get unclean output that will destroy speakers. If that supposition is anywhere near correct, then it seems to me that just doubling the impedance shouldn't automatically mean that the amp can only drive the speaker to 139W. A bit of a loss due to inefficiency, but shouldn't it still be able to drive nearly the same load? Say ~220W instead of 278W? Or am I totally, completely wrong? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Thanks for your help. I'm going to continue searching, to try and answer some of what I just asked. It's really the first question I'm having the most trouble finding a satisfactory answer to, so that is why I posted here.
Thanks,
Dave
Thanks,
Dave
