What is the difference between a Profile amp and a McIntosh amp???
Well lets see....
Nissan 350Z / Sentra
Toyota Supra Twin Turbo / Celica
Corvette Z06 / Prizm
McIntosh / Profile
Look at these test specs...
McIntosh MCC602TM (2 channel 600W)
MSRP: $3,500.00
Output power @1% THD 1kHz 14.4 volts
Stereo @ 8 ohms 2 x 392 watts
Stereo @ 4 ohms 2 x 418 watts
Stereo @ 2 ohms 2 x 350 watts
Parallel Mono @ 4 ohms 1 x 790 watts
Parallel Mono @ 2 ohms 1 x 840 watts
Parallel Mono @ 1 ohms 1 x 700 watts
Output power @1% THD 1kHz 12.5 volts
Parallel Mono @ 2 ohms 1 x 700 watts
Distortion at rated power
300 Watts x 2, 1kHz 14.4 volts = 0.0045% @ 2 ohms
Input sensitivity 1 to 8 volts
Frequency response (+- 1dB) 20 Hz- 50 kHz
S/N (A weighted,below clipping,2 v in) >116 dB
SEP (A weighted) >102 dB
Damping Factor @ 100Hz,4 ohms >56
Idle current 4 amps
Maximum current consumption, unclipped RMS 92 amps @ 610 watts
Efficiency at 1/3 power, 2 ohm per CH. 27 %
Efficiency at full power, 2 ohm per CH. 53 %
Power supply (regulated) Regulated to 10.2 V
Dimensions 27" x12.5"x 2.9375"
Additional Measurements
Out of Regulation: 1 kHz 10.1 volts, 20 Hz 10.7 volts
Idle current at 20 Hz with no load 5 amps
Slew rate (RCA input)
8 ohm 31 V/usec.
4 ohm 23 V/usec.
2 ohm 15 V/usec
I ship them the metal to make those amps with:).They shipped some metal back to us that came from the mill bad and in the box was a few amp hulls.The mac's not the profiles:)
I just asked McIntosh to have someone with good technical knowledge of their products to register and shed some light on the subject...lets see what happens....
unless they`re going to sell us the amps at profile prices it`s a waste of time. there`s no reason to spend that kind of money on a daily setup. i wouldn`t even spend it on a SQ car.
The profile will probably last just as long, and sound pretty much the same as the mcintosh if you put in on some mid grade door componants in stock locations. So who cares?
I wouldnt go as far as say last as long as I have seen a couple macs from the early 90s still going strong and I doubt the same could be made for the profile. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
But I doubt many would be able to hear the difference.
I would like to think that the QA with Macs is going to be better than profile. Also the variation from the reference should be better.
I mean if your running resistors that have a +/- .05 variance that can be a pretty big change from the original design. Also, I'm guessing Mcintosh makes a better profit on the audio equipment which gives them a better budget for R&D so you get better technology in the equipment.
sportyaccordy
sportyaccordy
NYC
Symon_say
