psycho72 10+ year member
Just like the title says. A guy here recommended power compression. I did a search and found a couple of pages of nothing, so here I am. Can someone explain what this is?
Say you throw 2K at a sub and put up a #....You throw 4K (doubling power) and you only gain 1.4 (where you should have theoritically gained 3) you have now reached power compression...Its when the coils heat up so much that the impendance will shoot so high the sub wont see the gain in power...
Here's a better explaination...
"First some basic concepts:
1) When current flows through a voice coil, it heats the wire.
2) The hotter the wire gets, the higher its DC resistance becomes.
3) If the speaker design is not capable of dissipating the heat, the DC resistance increase leads to an increase in impedance and shifts in the speaker's parameters.
4) This rise in impedance reduces the effective power driving the voice coil, which leads to non-linear behavior (a loss of output over what would be predicted at that power with a cold speaker).
In other words, your "4 ohm" speaker becomes a 6, 7 or 8 ohm speaker when the coil gets hot resulting in less power for a given voltage driving the speaker.
Let's say we design a speaker which is capable of dissipating the heat of 100 watts very effectively but is in significant compression at 200 watts. Let's also say this speaker is 4 ohms nominal.
If we run 25 watts (based on voltage^2 / 4 ohms) we actually get 25 watts into the coil and let's say we read 110dB SPL of output. Now we increase the power by a factor of 2 to 50 watts (again assuming voltage^2 / 4 ohms) and get a predictable 3dB increase (113dB) because the speaker is not in compression. Now we double the power again to 100 watts and get 116 dB... the speaker is still not in compression.
Next we double the power to "200 watts" and we only read 117.5 dB... Whoa? shouldn't we have read 119 dB? What happened? The speaker is no longer a "4 ohm" load... it is now a 6-7 ohm load and even though we thought we doubled power (because we increased voltage by a factor of 1.4), the impedance rise caused by heat ****** up some of the power increase, leading to less than 3dB gain.
That, in a nutshell, is power compression.
At some point we reach infinite power compression, which occurs when the coil gets hot enough to fuse itself into a blob of metal. ;-)"
lol, dont worry about him...No diss on you TEAM .. Just I admire those who spend their time to educate someone. Whether he copied it or not, he posted the answer ! And you downed on his efforts to help someone. This was my cross with you , and because you didnt state your arguement behind the theory with your very own answer , I sass'd your voice in this post .
I dont know your profound knowledge or proefficiancy with audio , but you neglected to tell him where he was wrong ! and why he was a NOOB . So , I tookit as a demeanor towards an educator. Teachers dont make their own theories to teach.. they use it from an establish factorial source , which he may or may have not done from the JL audio site you claim.
Why not post the link to the site that has the explination behind it. Either way, it was wrong for you degrading his efforts to educate.
Yeah that was my thought too but I don't know my shyt and general was gracious enough to help. I don't like to kick a helping hand in the mouth so I shutup and ask.Btw..why or better yet how would 2 woofers be more prone to power compression then 1 woofer if they are on the same circuit? And are also the same exact woofer...
I just want to know the theory behind this...i have NEVER heard anything such as that...or even remotely close to it...Yeah that was my thought too but I don't know my shyt and general was gracious enough to help. I don't like to kick a helping hand in the mouth so I shutup and ask.
Honestly man - If you plan on just daily driving and listening to music, you really do not need to worry about this //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif...otherwise it envolves a lot of math and a whole bunch of trial and errorAnd as far as pistonic compression is concerned then just optimizing a box for full excursion at X watts is not gonna cause it, so I don't really have to worry about it unless I srew something up or decide to go isobaric, right? Maybe?
You shouldnt have to worry about power compression when it comes to a "normal" install. Its a big factor when your trying to get as much out of your amps as possible for that one note. You have to play with the volume and port of the box till the impendance is at its lowest. Even the box positioning becomes a factor, you can move the box an inch one way and have the impendance rise .1x...Thanks Inhuman, that was a great explanation. Can I ask you to further explain general's comment that "2 subs , face this issue less than one sub does", how would two woofers lessen this effect, if at all?
From your explanation it would seem to me that it would be better to optimize my box to reach full excursion at 6-700 watts as opposed to just dumping 1200watts into a speaker.
**edit**ohh crap NV so then acheiving full excursion is also a bad thing?
