What is absolutely necessary to run this properly?
your gonna need a high output alt... and some about 4 batt's...
You sir have lost your mind. The amp is 2k rms and for that power with the highs amp one batt in the back would be fine. A ho alt isn't totally needed but, should be highly recommended.
read it he's running two of them!!!!!!!!!!!!!!!!!! lol guess i didn't need to put that as everyone else already did! lol and I just thought he'd rather be safe than sorry........
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif....yes murph, i believe u r correct that i have loss my mind (I seem to be under a spell it seems and i must have it:crazy:) and i will take into consideration the suggestion made by NASTY08IMPALA though i still do not know exactly what kind or how many batteries i need and/or alternator. So i am thinking
3 AGM batteries (1 under under) (1 @ each amp).....but i want to know exactly what type @ each location
1 HO alt 240amps
1. Take the rest of the recommendations here.... And throw them out the window.
2. Get the biggest alternator you can. You'll thank me later.
3. AGM battery in the stock location
4. 1-2 banks of ultracaps or G31 batteries in the back, if you must...
It takes power to make power. Alternators make power. Ultracaps and batteries store power, but ultracaps do so much more efficiently.
Start with high output alternator,put biggest agm battery you can fit up front and then one more agm in the back.either get same one as front or bigger.you can spend a lot of money on agms or a little less if going with a different brand than an "audio" battery.start with two batteries if voltage drops too much then add a third
Should be good to go without those fuses. Read the manual that comes with the new stereo. If it doesn’t say to add additional fuses, don’t.
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
I am out of the car audio world the more my ears age. However, I am very much still a hobbyist in the electrical field. With much of my current...
15
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
fire919
fire919
the bronx,NY
supra1987
    May 16, 2024
    May 16, 2024
