What is absolutely necessary to run this properly?
fire919
running @ 1ohms
i have the following and nothing else except speakers/woofers
110 amp alternator
1 standard battery (whatever that means) under the hood
2 ph4000md
1 ALPINE PDX 4.100
AMP specs
1 Ohm Stable Class D Mono Block Amplifier
Rms at 1 Ohm: 2000 Watts
MAX at 1 Ohm: 4000 Watts
Frequency Response: 10Hz ~ 220Hz
Input Level: 5V ~ 0.2V
Variable Subsonic: 10Hz ~ 50Hz
Variable Low Pass Filter: 40Hz ~ 220Hz
Switchable Bass Boost: 0dB, 6dB, 12dB
Alpine
Key Features
Amplifier Type Multi Channels
Channels 4
Input Voltage 10.5 volt
Bridgeable Bridgable
RMS Power at 2 Ohms 200 W x 4
RMS Power at 4 Ohms 100 W x 4
Replace under hood battery with a good agm, and add at least 1 or 2 more batteries in the back, along with a quality high output alternator to be safe.
why a head unit???...i thought it would be obvious (my bad) i have a HU already
...and i want to know how many amps at the alternator...what type of battery under the hood/trunk
Will this work?...or is this overkill?XS Power D3100 under the hood
240 amp alternator
Big 3 upgrade
definitely not over kill.... under kill, bro, I needed 2 batts, and a 260amp alt for 3000w... your gonna be running over 4000w.............. I'd have to say what you listed and atleast one other batt in trunk....... if not more..........
You will need upgrades. My old D'3s would kill my battery bank. 2 of them at .5 would rape my voltage very fast.
I had 2 under the hood and 4 in back. Ohio gen alt helped big time.
your gonna need a high output alt... and some about 4 batt's...
You sir have lost your mind. The amp is 2k rms and for that power with the highs amp one batt in the back would be fine. A ho alt isn't totally needed but, should be highly recommended.
Should be good to go without those fuses. Read the manual that comes with the new stereo. If it doesn’t say to add additional fuses, don’t.
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
I am out of the car audio world the more my ears age. However, I am very much still a hobbyist in the electrical field. With much of my current...
15
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
fire919
fire919
the bronx,NY
supra1987
pfft
    May 1, 2024
pfft
    May 1, 2024
