What is a light weight sub that can handle a good chunk of power?
Gbob2003
Great Odens Raven
So I am going to be putting a system in a cobra that im buying in a couple days, and I was brainstorming systems and im trying to keep the subs light but can handle around 2500 wrms. I dont want like a zcon or hdc4 or anything like that because weight will be a factor with the car because im attacking performance on it to. My current mustang wont fit any bigger than a twelve so im just wondering what is a good sub that weighs less than prolly 45 pounds. Thanks guys
I want a sub that weighs UNDER 45lbs... that can take 2.5kW rms though? How about you cut it down to about 1500w, since you won't notice the difference anyways, and get an SSA Icon. Since they're efficient as well, you won't need as large of a box. Plus, a 1500w amp is lighter and smaller than 2500w amp //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif And if you wanna save weight and space, I'd look into an Mmats amp. Unrivaled efficiency, so you don't have to upgrade electrical. And tiny for that cramped trunk.
^^^^^^this ^^^^^^^^^^
Fi Btl N2......But how much of a difference could 30 lbs make? If you are that worried about weight just make it easily removable. What electrical upgrades are you planning to run 2500 watts as that will hurt performance too.
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
I would assume they are pretty accurate as long as they are directly tied into the clip circuit on the amp. Having said that, the signal traveling...
849
I am not well versed in box design, so I do not know outcomes based on over/under sizing. The one thing I do know is that too big of a port will...
801
Big subs have heavy cones. Heavy cones plus high power requires solid anchoring and solid enclosures. Most people don't anchor their boxes to the...
16
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
Gbob2003
Great Odens Raven
Gbob2003
Marine corps base hawaii
rebelfromva
