What impedance would this create?
45auto
I have two DVC 4 ohm drivers wired to 2 ohms a piece, independently wired, and they're connected to a mono amp, with two positive, and two negative inputs.
The amp went into protection, and then shut off completely, I think the fuse blew.
What impedance am I creating?
I want to get a 2 ohm, but I'm thinking that I may be creating like a 1 ohm load or something. How can I get a 2 ohm load?
If you have a pair of Dual 4 Ohm drivers wired in parallel (which creates a 2 Ohm load for each driver independently) and then connected those two drivers to the same mono sub amp then you've dropped a 1 Ohm load onto it and if it is continually going into protection I would say that is indicative of the amp not being a 1 Ohm stable unit.
You cannot get a 1 Ohm load with a pair of Dual 4 Ohm drivers.
See this diagram for the possibilities with a pair of Dual 4 Ohm subs
Edit: MikeyB beat me to it! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Dont tell me it is a Directed refurb.
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif HAHA!
You've got it wired at 1 ohm, those two outputs are wired in parallel with each other inside the amp.
45auto
45auto
Buffalo, N.Y.
Pyro_By_Nature
Mike Mccabe
